Have tiptronic know? Can increase and decrease by using lever plus minus sides
OK so you do have tiptronic.
Find the diagram in eper that shows the part you are looking for then look for it on your car.But why it is available to my car when checked by entering VIN in fiat eper.?
you can easily test the electric power steering unit using a car battery and a multimeter.
there are 6 wires:
black - earth
white/red - live (12vDC)
blue - ignition live (12vDC)
purple/black - city mode switch (live or earth to switch modes)
pink/white - signal for City mode light or steering system light on instrument cluster
pink/black - signal for City mode light or steering system light on instrument cluster
first you need to determine which of the 2 pink wires is for the city mode light. to do that wire up the live and earth and ignition live. now use a multimeter (black terminal on earth, red terminal on wire) on either of the 2 pink wires and try switching the purple/black wire live and then earthed then live then earthed etc. check to see which of the pink wire's signals switches on and off as you do this.
the wire with a signal that switches on and off is the city mode light wire. you then know the other wire is for the steering system light.
now attach the multimeter to the steering system light and disconnect the blue wire from live. now reconnect the blue wire and check that the steering system light wire has a signal for a couple of seconds. if the signal stays on it means there is a fault in the electric power steering unit. if the signal switches off after a couple of secs it means the electric power steering unit is working fine.
