About a year ago I first got this error p0352, but the car ran fine apart it sometimes gave this error. I changed the plugs, leads and coil packs. However now couple of months ago it gave this error again and today it suddenly when I was driving light up the motor light and start running on two cylinders.
I read the error codes and it gave p0352 and it didn't help to clear them because it always gave it again when I started the car. It runs on two cylinders and I tried with different coil packs and it always gives the same error code. Is this now probably the ecu or could it be somerhing else I should first try? Are the self programming ecus from ebay ok because they are probably the cheapest way of changing the ecu? The model is mk2b 8v and year 2004.
