J jte Member Joined Sep 16, 2005 Messages 162 Points 131 Jun 14, 2017 #1 Hi, what is the best method to remove ignition switch shear bolts? Thanks Juha
J jackwhoo Distinguished member Joined Apr 8, 2017 Messages 6,153 Points 1,400 Jun 14, 2017 #2 Drill head off shear bolt , remove lock assembly , unscrew remaining part of bolt. Bolt steel is quite soft and easy to drill.
N Nickhmh New member Joined Nov 1, 2016 Messages 140 Points 41 Jun 14, 2017 #3 jte said: Hi, what is the best method to remove ignition switch shear bolts? Thanks Juha Click to expand... Long nosed mini vice grips on the exposed threads. That's how I removed mine. Cracked loose real easy
OP OP J jte Member Joined Sep 16, 2005 Messages 162 Points 131 Jun 14, 2017 #4 Vice grips doesn't destroy threads?
N nitramtpr Patron member Parked in the garage Joined Aug 15, 2013 Messages 457 Points 165 Jun 14, 2017 #5 jackwhoo said: Drill head off shear bolt , remove lock assembly , unscrew remaining part of bolt. Bolt steel is quite soft and easy to drill. Click to expand... This is what I did, I replaced the bolts with allen headed bolts when I put the new lock in.
N Nickhmh New member Joined Nov 1, 2016 Messages 140 Points 41 Jun 14, 2017 #6 jte said: Vice grips doesn't destroy threads? Click to expand... Not if you're careful'). You only need to grab the very end .
multipete Established member Joined Jul 7, 2006 Messages 719 Points 238 Location Lancs now Flkestone,Kent. Jun 14, 2017 #7 Or centre punch and hammer on head to loosen.
F flisko ` Parked in the garage Written 5 guides Joined Jan 20, 2013 Messages 6,151 Points 1,228 Jun 21, 2017 #8 multipete said: Or centre punch and hammer on head to loosen. Click to expand... tru dat hammer+screwdriver or chisel to loosen and pliers to unscrew
