The Trooper said:6000 rpm if i remember correctly. I thought ELX trim Punto's only cam with 16v engines
JamesMK2 said:there was never a 12v engine fitted into the punto mk2.
As for reving higher with the mapping red-line stays the same as fixed mapping cuts back in again at around 5400-500rpm.
Its a lovely noise, i agree. The mk1 8v puntoThe Trooper said:How I miss the sound
Catseyes said:6,500RPM actually, however my fellas one is remapped and the limiter is 6,650.
wish I could on a mk2, alas I can't, it being mpi and different wiringjamie86 said:Stick a Cinq ECU on it much more fun
Catseyes said:wish I could on a mk2, alas I can't, it being mpi and different wiring
However the cinq ecu and 1242 in the cinq, is fun!
