Old 16-03-2017   #1
Finland
Question Rough running at idle and serious judder at low RPM in gear
This sort of follows on from;
https://www.fiatforum.com/punto-ii/4...-hot-cold.html
The engine cutting out seemed to go away once I got a new alternator.
However....
Engine was running rough on idle although luckily not stalling. Every few seconds it seemed to choke, when I had engine running with the airbox removed I could hear an air suction sound when the choking was happening. Still not sure if this is a sympton of anything.
As well as this, and actually a lot more annoying is how the car performs when driving at low RPM. At almost any speed although I think worse at lower speeds, when I back of the accelerator, the car judders really quite badly. I have to drop the clutch to stop it. It also hesitates / judders when putting my foot back on the accelerator. It's basically un-driveable in traffic with foot just pressing the accelerator slightly as it judders then too.
I had thought it might be misfiring so changed the spark plugs. It actually got worse and now stalls after maybe 10 seconds or so unless I give it some rev when it sounds like it will stall.
I'm reluctant to bother changing the HT leads as well (quite expensive), my feeling now is that it might be the MAP sensor. I randomly removed the power from the MAP sensor and it idled much better. However the juddering whilst moving still remains so not sure if the two are even linked.
Does anyone have a ****ing clue what might be going on ?
I'm thinking I might try and remove the MAP sensor and clean it? Not that it'll probably make any difference. Have to buy a star/torq whatever the hell it's called screwdriver to do this.
Summary of ramble;
Symptoms;
1) Rough Idle, choking every few seconds. Since changing spark plugs now stalls.
2) Awful kangaroo judder when backing off accelerator, driving with just a touch of throttle, and hesitation / judder when putting foot back onto throttle.
Have tried;
- Changing spark plugs. Car now stalls on idle
-Removing MAP sensor power cable, seemed to improve idle but still judders when driving.
Cheers,
Paul.
PaulTobiasx1/9 is offline Reply With Quote Quote
Old 17-03-2017   #2
Finland
Re: Rough running at idle and serious judder at low RPM in gear
Can also remove the idle stall problem by unplugging what I think is the throttle position sensor, the higher, smaller further back one on the left hand side of the throttle body and plugging the MAP sensor back in.
Either way I still have the awful kangaroo judder issue when removing my foot from the gas or having it just slightly on at constant speed.
Paul
Old 17-03-2017   #3
flisko has donated!
there is no point in buying new parts
get used ones and change them on the spot, explain to the seller if car will work normaly you will buy it
flisko is offline Reply With Quote Quote
Old 18-03-2017   #4
Finland
Quote Originally Posted by flisko View Post
flisko,
That is a good idea, but I don't know anywhere here in Finland I could even do that ?
Paul
Old 18-03-2017   #5
Finland
Does this video help to understand what is going on when I have the MAP sensor plugged in and engine is idling ?
The engine stalls a few seconds after the end of the video.
Without MAP sensor, e.g. unplugged, it doesn't stall but does run a little better. Though when driving still have awful judderyness.
Old 18-03-2017   #6
flisko has donated!
you sure yellow engine light isnt on?
Old 18-03-2017   #7
Finland
Definitely no light. Maybe the light is broken ?
Do you think I'll be wasting my time getting a MAP sensor ? Should I consider buying a fault reader or just taking to a garage ?
Paul
Old 19-03-2017   #8
Finland
Well I guess I'll just buy the sensor and report back. Not sure what else to do right now.
Old 19-03-2017   #9
flisko has donated!
first plug it to computer to check for errors, what city are you from
if you live near kajaani i know someone there who can check for errors
Old 19-03-2017   #10
Finland
Unfortunately not close at all...
I got mousebuttontrigger happy and ordered a new MAP sensor.
I've just noticed that the oil is also going missing pretty swiftly, I'm guessing this is probably another symptom that either is bad and unrelated, or bad and related and means the MAP sensor will make no difference.
Could misfiring cause quicker fuel burn ?
Paul
Old 20-03-2017   #11
Finland
Quote Originally Posted by PaulTobiasx1/9 View Post
Paul
I meant quicker oil burn
Old 22-03-2017   #12
Finland
MAP sensor didn't work.
Can make the engine run on 2 cyclinders by unplugging one coil at a time so would guess it's not that ?
As far as I can see I'm left with;
-Some air leak
-Problem with Throttle Position Sensor or Idle Air Control valve / motor thing
-Engine Timing / head gasket / some other thing I don't understand.
-ECU even ?
I think I might change the throttle body unless there is some implication with the ECU ? Then take to a garage as anything else I wouldn't be able to do myself anyway.
Paul
Old 22-03-2017   #13
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
mine has this sorta weird hunting issue as well
the revs drop and engine recovers and it'll then stutter again
except mine isn't getting like your to the point the anti-stall is kickin in hard
The Bypass idle valve sounds like it sticking
But tbh on a punto i've never tried to cure it
mine is often worse of heavy electrical demand
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 22-03-2017   #14
Finland
Quote Originally Posted by Ziggy122 View Post
Ziggy
Have not really tried with/without electrical load to test difference.
I've gone through so many theories now I think it's probably time I have to give up and take it to a professional.
I suspected maybe throttle position sensor or stuck IAC valve.
I did a small test and found that the TPS is on multimeter giving expected readings, 0.75 and climbing as throttle opens.
I'm getting misfire / stutter with revs well above idle as well so I'm guessing I actually have some serious issue inside the engine, piston rings or valve something or others ?
I noticed only a couple of days ago I seem to be burning oil quite fast. I think this ties in with the piston ring thing, and I guess would explain the misfire as well ?
I managed to try another map sensor at a scrap yard which made no difference, luckily didn't have to buy it.
If you didn't read all my earlier posts, current situation is that I cannot drive anywhere unless TPS is disconnected. Why this is I actually have no idea. At one point I could drive it with either the TPS or MAP sensor disconnected. Now it's down to only going if I disconnect the TPS. If I disconnect the Idle Air Control motor and start engine it revs to infinity. Is this expected behavior as the valve is set to full open with engine off maybe ?
Never had this many problems this quickly with any other car in my life !
Paul
Old 22-03-2017   #15
flisko has donated!
bad coil pack would turn on engine light, but still if you wont scan for errors you are just guessing, without another car for parts its not that easy
(T) Poor running at low rpm and low mpg.... mick_with_cinq Bravo 4 12-02-2013 20:26
(T) Rough idle , low mpg 5APPH1R5 Multipla 12 21-09-2012 00:40
(G) To low rpm at warm idle, RPM sensor? Migaard Marea 13 29-05-2007 16:47
To low rpm at warm idle, RPM sensor? Migaard Newbie Central 2 25-05-2007 19:26
