dubsential
- May 31, 2016
- 91
- 33
Hi.
To anyone that can help I have a jtd punto with alot of modifications.. Remap etc
As the gearbox was shot I'm replacing the clutch it didn't slip before and I believe it is standard.
I would like to add a slightly better one out of the hgt jtd as it's rated slightly higher hp.
I got the idea reading a thread and would like conformation whether it will fit as part numbers are different.
It is the same size and same amount of teeth, also on the spec sheet for the hgt clutch it states it's suitable for the 5M box the jtd has. So it should be only the flywheel fitting being an issue.
Valeo jtd flywheel is fitted currently and I wish to keep this.
Thanks in advance if you can help.
