Hi there may be a thread for this but my apologies I can't find it.
My daughter has a 1.3multijet diesel punto 53 plate.
It takes forever to start, I took off the leads to the glow plugs and checked the voltage to them 2 have zero volts 2 have 11.45 volts when ignition is switched on, Glow plug light comes on and goes off as it should.
I thought glow plug relay. I cannot find it for the life of me. Heard it was by the egr valve No IT isn't then bolted to bulkhead I can't find it.
Please help as it is driving me nuts. I have checked all the fuses in the fuse box next to the battery and they are all good.
Is it the thing to the right of the abs pump covered with a plastic sleeve bolted to the inner wing?
I am wondering if it is in a different place as this car has abs air con reversing sensors all the add ons I know it shouldn't make any difference but where the hell is it.
