Old 10-02-2017   #1
Exclamation ESP and Hill Hault Lights
After reading the other threads, some things are common however there are some differences. I've just had my break pads and discs replaced, in the hopes this would help. It didn't.
I have the engine warning light on, ESP warning and Hill Halt warning light. The car drives normal, and seems in perfect working order, apart from obviously the errors being displayed and the the things they do, now don't work.
Yes it's cold and damp and has been for the past month, however the issue only happened two days ago, and hasn't changed.
Any idea's on what to do, to see if it helps?
Many thanks for your time
KyleDavis is offline Reply With Quote Quote
Old 10-02-2017   #2
Re: ESP and Hill Hault Lights
Quote Originally Posted by KyleDavis View Post
The exact same thing has been happening with our punto over the last few week.we Have had the pedal switch and battery replaced today to eliminate them have also noticed the cooling fan constantly running and that the temperature needle doesn't move when these faults all come on at the same time.
I will be following you're thread to see what others say.
DIDCOTT is offline Reply With Quote Quote
Old 10-02-2017   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Need to code read to find what the abs/esp/traction control unit thinks is wrong....
Millions of reasons tho...
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 11-02-2017   #4
In addition, today I have noticed the fan is racing and the temp gauge is either reading zero or not working. Hard to tell.
Old 11-02-2017   #5
Exactly the same as ours. I had the codes read and p0115 coolant temperature sensor circuit came up. After doing some research on here I'm going to check the wiring and earth strap to eliminate them as the temp sensor is new and this has been happening before it was replaced.
Old 11-02-2017   #6
Quote Originally Posted by DIDCOTT View Post
Any chance you could advise me, on how to do the same. Would be greatly thankful I'll also keep you updated on any changes I get, that could help you as well.
Old 13-02-2017   #7
Charlieboy13 has donated!
As Ziggy has said the best bet is to get a code reader on it.
A common fault is the temperature sensor but it could be any manner of things.
Wheel Speed Sensor, Faulty ABS Sensor.
I even had mine come on due to a bad earth on my rear light cluster.
Charlieboy13 is offline Reply With Quote Quote
Old 13-02-2017   #8
I'm taking it in tomorrow to have it looked at. I'll update what I'm told when I get the diagnosis in hopes it'll help others
Old 14-02-2017   #9
Wait what?
Were blaming a System that not even related to it?
A Engine Temperature sensor is going todo NOTHING with the Hill Hold / ESP setup
My advice - punto's are little ****s when it comes to low batteries - can always get the battery for free at halfords
Ziggy
Meet Bumble-Bee
Old 15-02-2017   #10
Aye. Battery was down to 53%. Replaced it with a new one this morning, and the lights have gone. Low valtage guy said and explained he owned one before and had same issue with battery. Quick, cheap fix. Cost me grand total of 50 and that includes new battery, fitting and diagnostic plus a couple of other little jobs he did, such as pumping up the tires, fixing airbag light etc.
Old 15-02-2017   #11
That's good news wish that that was cure for ours.
Ours have gone off for now so will check the earths at the weekend and check the alternator is working and charging the new battery properly
(T) Engine, ESP, Hill Holder Failure Lights, MKIIb davzie Punto (Mk2/2b) 17 10-07-2017 11:55
(T) Esp - hill start not available Colf Bravo 1 13-01-2017 23:03
(T) Punto christmas lights! ASR,Power,Hill,ESP dangorusdave999 Punto Evo 5 26-11-2015 12:06
(T) ESP + Hill Holder pranksta Grande Punto 5 29-10-2009 09:45
(T) esp and hill holder marty27 Grande Punto 9 11-11-2008 13:48
