My punto was giving me trouble starting a few weeks ago, turning on engine runs then stops and can't restart again. I managed it for a few weeks by revving the engine when I started the car and could get it to run. Now though it just won't start, I can't hear the fuel filter hum like I used to be able to. There are no strange symbols on the dash.
I think it may be the fuel pump relay needs replacing but I can't work out where it is. Everything I read from searches tells me conflicting F numbers that don't exist in my fuse box.
I've also tried to locate the inertia switch under the carpet on the passenger side but wasn't sure I found it. There were a few round button like objects but nothing that clearly shouted inertia switch.
I've taken the below photos, can anyone tell me where the fuel pump relay and inertia switch will be in the photos? Assuming I've taken a photo of the correct location!
Other things to know, the fuel pump is brand new from a few months ago, an incorrect diagnosis of the same problem. I tested the battery and it's read 12.1 volts. I've also hooked up another car battery but still can't hear the fuel pump hum.
Really hope it's as simple as the relay! Any other ideas are very welcome. Thanks in advance
Fuse panel in engine up close
Fuse panel in engine zoomed out
Fuse panel in cabin on driver side
Passenger side, inertia switch there somewhere?
