General Exhaust Flange Nuts/Studs Size?
alan01256
Ok so just replaced the complete exhaust system on my nieces 1.2 Punto Active (54 plate).
A simple job apart from where the system joins the down pipe flange. I was surprised to find the nuts were 12mm AF rather than the expected 13mm AF, plus when I went to replace the nuts with new ones I found the threads were not the standard 8x1.25mm.
So where do I get replacement nuts or do most people just drift out the spot welded studs & replace the whole lot with standard size (M8x1.25mm) bolts & nuts?
Hadn't realised I had not closed this thread off. In the end I simply knocked the old studs out & refitted some standard M8 bolts, nuts & washers. Exhaust was not only cheap (£42 inc clamps & gaskets) & dead easy to fit. Beginning to like this little car as all the jobs seem so simple & as it fits nicely in my garage don't have to worry about the weather.
