Hey there!
I am looking for some advise from you guys.
I am having a problem with my 2004-Punto 1,2 8v, I can't solve.
The following has happend:
I had a breakdown og the highway last wednesday. When the breakdown happen everything was working as normal. Not too hot - enginetemperature was at 82*C, plenty off fuel on and no lack off power.
Suddenly it just lost all power and the enginelamp started blinking (Yellow/orange). A few seconds later the oil- and batterylamp came on and the engine was dead and wouldn't start again at all.
My tester shows misfire on cyl. 4
After my car was transported back home, the following troubleshooting has been done and checked:
- Timing belt, still looks perfekt and marks lines up.
- Coil packs, both is working fine
- The sparkwire is working fine
- Spark plug on cylinder 4, was sparking fine
- The fuel pump is working as normal (sounds normal)
We did find a lot of oil at spark plugs 1,2,3 (most at 1 and 2).
The car won't start at all, not even with cleaned spark plugs (They are all fine) - The starter turns over fine but nothing more happens. Also we also tried with forced petrolintake by closing for airintake.
Does everybody know what the problem is? Blown headgasket? Broken valves? Or something else?
Is there no another way then changing for a new motor?
Thanks!!
/Mathias
Thanks!!
/Mathias
