- Jan 20, 2013
- 6,151
- 1,228
have fun..!!
try and take pics as you go..,
Charlie
have fun, nice
have fun..!!
Charlie
have fun..!!
Charlie
was head gasket actually blown?
does it still show misfires?
The tester shows nothing but the battery has been off as part of the replacement of the gasket, so I guess the ECU has been reset....
hi,
check you've got the bottom pulley on the correct way.. there is a tiny pin hole / and pin for alignment
just cranking MAY log a fault code - IF there is any fault to report,
see if you've still got a spark.., https://www.fiatforum.com/members-motors/308369-non-start.html
then listen carefully when cranking..does it "CHUFF" / seem to burn fuel..?
if nothing.. CAREFULLY spray a small amount of fuel / east start into the throttle body, and briefly crank again,
if this gets a response / attempt to fire.. it points at a fuelling issue,
does the tank pump under rear seat "HUMM" for @5 seconds when turning ignition on..??
Charlie
The link suggests.
No fuel and liitle spark are a lack of timing signal input..
So check the sensor and crank pulley.
That crank sensor seems to be missing the pin in the middle, or was that just the MK1
its on mk2 too
Look, look, it drives, it drives...
Thanks alot for all the help guys! :worship:
However, it was apparently not the crank sensor that prevented the car from starting. The whole issue was related to the fuel and I do not know why it was not checked earlier what the quality of the fuel in the tank was.
Even though I have a receipt from the local fuel pusher INGO on unleaded 95, it appeared that the tank contained the absolut finest mix of both diesel, water and gasoline. :bang:
Cleaned the tank and filled it with new petrol - Boom, it just jumped into action again... but now it ticks like hell :bang:
GOOD TO HEAR IT'S RUNNING..!!
Sorry to hear of the saga..
TICKING..?? from the top of engine / valvetrain, ?
or maybe the injectors working extra hard..??
Diesel might have cleaned the injectors ??
These cars can be quite noisy from the injectors. Mine are pretty bad.
