Thread Tools
Old 30-05-2016   #1
16v ECU swap
Just curious, can I swap the ECU in a 2003 MK2B Active Sport 1.2 L 16v without any difficulty or do I need to change the ignition barrel, locks and key too?
quaffle is offline Reply With Quote Quote
Old 30-05-2016   #2
brinker has donated!
Denmark
Re: 16v ECU swap
As far as I know ECU is not a problem.. Replacing body computer is
Personal Best Lap Times:
Circuit Park Zandvoort - 2:37.89 (Fat Amy @65BHP)
brinker is offline Reply With Quote Quote
Old 30-05-2016   #3
jazz452 has donated!
Re: 16v ECU swap
Quote Originally Posted by quaffle View Post
Do I hear spoke too soon
jazz452 is offline Reply With Quote Quote
Old 30-05-2016   #4
Up to no good somewhere..
maggers's Avatar
maggers has donated!
Re: 16v ECU swap
Quote Originally Posted by jazz452 View Post
Certainly did, my Northern friend! You need keys, body module, locks & ECU. All off a 2B because 2A ones are different.
maggers is offline Reply With Quote Quote
Old 30-05-2016   #5
Re: 16v ECU swap
Quote Originally Posted by maggers View Post
Or a virgin ECU for £65, 5 minute job.
Old 30-05-2016   #6
flisko has donated!
Re: 16v ECU swap
what seems to be the problem?
in order for the car to start, you cant only swap engine ecu, unless it is plug and play virgin
you need engine ecu, body ecu, inition barrel lock, key, and immobilizer ring
all door locks are optional, you can have 1 key to start car and other key for locks, unless you got remote central locking key is almost not needed
flisko is offline Reply With Quote Quote
Old 30-05-2016   #7
maggers's Avatar
Re: 16v ECU swap
You don't need the ring, it's just an aerial.
Old 30-05-2016   #8
flisko has donated!
Re: 16v ECU swap
you need that ring
Old 31-05-2016   #9
Re: 16v ECU swap
Haha. Not because of the misfire but because of this battery drain I'm having.
The only thing I can think it might be now is the ECU it's self. Who knows what's going on in there and something could be slowly draining the current.
Where can I get a virgin ECU for 65 pounds? I've checked eBay but can only find virgin 8 v units.
Thanks.
Old 31-05-2016   #10
Re: 16v ECU swap
Better searching by code off the ECU , probably right though maybe 8v onlynever heard of one going causing a drain, you've definitely double checked the earth on bell housing.
Old 31-05-2016   #11
Re: 16v ECU swap
Better searching by code off the ECU, never heard of one going causing a drain, you've definitely double checked the earth on bell housing.
Yup, cleaned up all the earthing points.
Old 31-05-2016   #12
Re: 16v ECU swap
Have you parked the car in complete darkness to see if any lights are still on.
Remove the negative clamp at the vehicle battery post.
Place one lead of a test lamp on the negative post of the battery and the other on the negative clamp lug.
The lamp glows if there is a parasitic drain.
The lamp will be dead, if there is no drain.
Just read it is possible for an ECU to cause battery drain.
http://www.honestjohn.co.uk/forum/po...ex.htm?t=70177
Turned out be power steering ECU
Old 31-05-2016   #13
flisko has donated!
Re: 16v ECU swap
Thanks.
that battery drain of yours, did you do parasitic test?
To do this, set your multi-meter to “amps”.
Disconnect the positive battery terminal. Connect the negative probe of your multi-meter to the battery terminal connector and the positive probe to the actually battery post...
Old 01-06-2016   #14
Re: 16v ECU swap
Quote Originally Posted by flisko View Post
I have done this and the multimeter shows no reading. I'm guessing it must be too small to detect? The guy in that thread was showing some drain with his power steering problem.
Old 01-06-2016   #15
Re: 16v ECU swap
Wonder if you could cut the power to steering and see if it stops
Thread Tools
(T) 2002 seic swap 1.2 16v ori ECU thoontjepower Cinquecento / Seicento 19 12-10-2015 17:22
(T) ECU swap due to no spark- any way to use a secondhand ECU ? richardllew Punto (Mk2/2b) 16 31-12-2013 15:55
(T) 1.2 16v Sporting Rad Fan On Constantly/Ecu Swap & Programming gary2208 Punto (Mk2/2b) 3 05-04-2013 14:48
(T) Immo question on 16v swap with ECU 18FD.5Z vatza Cinquecento / Seicento 6 16-03-2011 20:30
(T) ECU Swap (like wife swap but different!!) richydraper Cinquecento / Seicento 4 25-03-2007 15:12
