Hi all, first post so I hope I'm doing this right?
I recently bought a 52 plate Punto Active Sport 8v for my daughter, but of course it only has one key, it's blue and quite worn, (it has a Code 2 stamp on it) and I normally have to fiddle a bit to get it to turn. I need to get a second key, but if it is 'copied' it will copy the wear as well, so should I get it cut from the code? I don't have a note of the key code, so where/how do I find it? and does the new key have to be coded to work. I have been given conflicting info so far and dont want to waste money if I can avoid it. Can I remove the lock barrel and give it a clean and some lube to help things?
Thanks to all replies.
