deeinlondon
Member
I've got a year 2000 Punto sporting Mk2
I've read that the suggested replacement is usually NGK DCPR8E-N Part No 5692
From what I've read the number 8 in the NGK numbering system is how hot or cold the plug is.
is there any benefit using a spark plug that is colder - i.e. a number 9 plug?
From what I've read the lower the number, the hotter the plug and the more it will burn carbon deposits on the spark plug to keep it clean, but if you go for a colder plug then heat will be drawn away from the plug faster so it stays cooler but in turn may mean the plugs get fouled sooner.
I don't mind changing spark plugs more often if it means more MPG or other benefits.
Also is there any huge dangers from running a hotter plug then an 8 - like a 7? Most of my journeys are short local journeys in London, but a few times a year I go camping and drive 100 to 150 miles at a time.
