Cheers, that worked perfectly
Although was still a struggle to get the box off, but got there eventually.
Took a while to also get the plugs off as the leads were so short and so tightly clipped into their separators, I don't have a blower but used a Dyson to vacuum around the engine and in the 4 bays.
I noticed when looking down the bays with a torch that the 1st spark plug, on the left appeared to be a tiny bit rusty at the very bottom, the other three looked fine, so I sprayed a little PlusGas into each bay and thought I'd wait an hour before turning the spark plugs.
I've read that it's a good idea to turn the plugs 1/8th tighter first to crack any corrosion that might be in the threads and then 1/4 turn looser and then allow the PlusGas to work it's way through the threads overnight if possible?
I'm in no hurry, I'd rather take things slow and steady.
