Old 04-02-2016   #1
03 punto active sport 1.2 8v won't rev past 3.5k
Ive been having this issue with my Punto for a couple of weeks now and have had enough of it.
She starts first time every time and runs as smooth as the day I got it.
The issue is when you get to 3.5k rpm. It happens when I'm in gear and parked up. As soon as you reach 3.5k rpm the revs drop and bounce between 2k and 3k and the engine management light flashes on.
I've checked all the spark plugs, spacings and leads. I've even replaced the MAP sensor and cleaned out the throttle body.
The car drives perfectly, mpg is good (better with this issue) but you just cant work your way up the gears properly. I'm having to change up early all the time other wise the car jerks and you end up losing a load of speed.
I'm running out of ideas so any help would be great.
Venox is offline Reply With Quote Quote
Old 04-02-2016   #2
flisko has donated!
Re: 03 punto active sport 1.2 8v won't rev past 3.5k
fuel pump
flisko is offline Reply With Quote Quote
Old 06-02-2016   #3
Managed to borrow my cousins punto today, spent some time swapping stuff from his car to mine to see what the problem was.
We started with the fuel pump and the issue was still there. We swapped throttle bodies to rule that out, still the same.
As we were about to give up we swapped the crank position sensor and BOOM success at last.
Crank position sensor ordered and on its way for tuesday.
Happy Days
Likes core liked this post
(T) 500 Twinair won't rev past 3000 on full throttle Popey500 500 10 03-11-2016 19:40
(T) HELP! Punto 60 won't rev past 4k! ianweaver Punto (Mk1) 19 12-06-2013 18:19
(T) Seicento won't rev past 3000rpm! davesei Cinquecento / Seicento 5 20-11-2011 19:59
(T) Cinq 1108 won't rev past 4k, suggestions? BiAS Cinquecento / Seicento 6 13-03-2011 22:48
(T) seicento won,t rev past 3000rpm big cheese Cinquecento / Seicento 34 02-02-2011 19:54
