im Axle Specialists
Old 18-10-2005   #1
Punto ignition relay problems, I think
Mk1 Punto was dead to the world, nothing happened when key inserted. Left it for two days, thinking it was a dead battery, and came back, put in the key, started first time.
Only sign is that the clock is now three (or 3+12, 3+24 etc) hours slow.
Any ideas?
It started fine at 0830 this morning, and then refused to start at 1000 - so I'm thinking that it's a dodgy relay.
Your thoughts?
pinkpunto is offline Reply With Quote Quote
Old 18-10-2005   #2
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
Re: Punto ignition relay problems, I think
hmmm fact that clock is out means that at somepoint there was no power at all not even enough to keep a lil clock going. not sure about relay that could explain the no activity when key turned. but the clock could mean a loose connection. check the batetr make sure the terminals are on tight. i had once come off once when driving dint know untill it would notstart next time.
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
(T) Fiat Punto ECU Wiring Diagrams arseofbox Punto (Mk1) 10 23-12-2009 14:28
(G) Buying a Punto from auction! SpunkyM Punto (Mk2/2b) 11 21-12-2007 20:19
(T) Punto 75 Cam's DJ_Bucho Punto (Mk2/2b) 13 07-01-2005 01:30
dead dumped blue punto A2 dave Spotted / Was It You? 5 07-11-2004 16:33
