Hi there,
I've been reading this forum a lot, ton of useful info here, thanks all for that! However, I couldn't find any help to my problem. I have a 2005 Punto, not sure which mk. Now to the problem:
The car keeps cutting me off, seemingly random, sometimes at junctions, sometimes while driving. When it happens, the battery and other lights are coming on, just like when you stall the engine and it stops. As I try to restart it, the CODE light comes on, and the car doesn't start. I have to wait about 10 minutes, with the key out from the ignition to be able to start it. After that it starts and drives fine until another random point, sometimes 20 minutes, sometimes a week later when it stops again. Also, the car behaves a bit funny, sometimes powerless and sluggish under 2000rpm, sometimes revs itself to 2000 and back in idle, which goes away if I stop the engine and restart it in a minute. These might be completely unrelated to the cutting out, just telling you, to give as much information as I can.
Someone suggested that the battery could be the problem, so I replaced it with an almost new one. Only thing is, the one that was in it had 440A, the new has 340A. Could that be the problem? Or probably something totally different, I am completely clueless about cars. I really have to solve this cheap as I can, please help me figure out what could be the reason for all this. Thank you!
