Hi, First time on this forum so sorry if this has been asked before.I am having problems starting my 95 1.1 55sx. The key code light is either remaining on or flashing intermittently as is the injector light. The engine spins and will start one time in 50+ attempts then runs with the keycode light on permanantly.I have changed the outer ring on the barrel with no change to symptoms. Ihave spoken to a company that can supply code free ecu's for about £200 which will bypass the imobiliser cct but do you think a diagnostic test would be advisable first? (my nearest Fiat dealer is 10 miles so quite a long tow). Someone has also told me that as I have tried starting with the red key I may have corrupted the code, is this right?
