Old 15-07-2015   #1
Marc Lewis has donated!
Low oil pressure warning light. Oil pump replacement?
Hi all. I have a 2003 fiat punto sporting. The oil pressure warning light came on yesterday. I've replaced the oil pressure switch but that hasn't cured the problem. Anyone have any ideas? If it is the oil pump failing, what is involved to replace it?
Any help would be much appreciated. Thanks
Marc Lewis is offline Reply With Quote Quote
Old 16-07-2015   #2
Re: Low oil pressure warning light. Oil pump replacement?
Is there plenty of oil in the car?
Rule out wiring faults first but it does sound like there could be a problem with the oil pump to which the first question would have to be why??
Oil pumps rarely break so either it's something silly like the oil pick up is blocked with crud or something has gotten in and damaged the pump.
I think I'd start with taking the sump off and looking at the pick up.
Maker and voice behind the YouTube channel PuntoHowTo 12k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 18-07-2015   #3
There have been cases of the oil pick up pipe in the sump cracking at the top where it joins the pump so the pump cant draw the oil up.
The other possibility is that the pump is fine but engine wear to the bearings is allowing the oil to flow out too quickly dropping the pressure.
Last possibility is that the oil feed bar in the head has popped off allowing the oil to flow out too fast and dropping the pressure. You can check this by removing the rocker cover.
darashen is offline Reply With Quote Quote
Old 18-07-2015   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Quote Originally Posted by darashen View Post
Its a sporting
The cams are held in via cam cover so belt will need coming off todo that im affraid
Some cars if the oil filter is blocked it can bring up low pressure warnings
Has the oil and filter been changed at all // recently??
Oil pumps are often blaimed for not generating pressure, but oil pumps dont
They generate volume
The pressure is generated by all the tolerances of bearings and shells in the engine
Is the car at all tappety?
Has a new sump been fitted?
Whats the oils colours?
Any smoke out the back of the car?
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 18-07-2015   #5
Quote Originally Posted by Ziggy122 View Post
Its a sporting
Sorry forgot it was a 16V when I suggested checking the top oil feed. Out of curiosity is the slight power gain worth all the extra aggro that comes with the 16V engine.
Old 19-07-2015   #6
just saved the owner a hella problem that all
it could be anything from a blocked pump pickup to a excessivly worn big end causing loss of pressure
Idearly the OP needs to have the oil pressure tested with an external tester to ensure it an actual case of low oil pressure
Ziggy
Meet Bumble-Bee
Old 24-07-2015   #7
Thanks guys. The oil and filter were changed about a month ago. Had a pressure test done and there is plenty of pressure. Leads me to believe that its an electrical fault with the low pressure warning light, I have seen a thread somewhere on here about it once before.
Old 10-01-2016   #8
We have the same oil pressure warning light - coming on when cold - then going out and not on again until another cold start on our '04 Punto 1.2 8v. 110,000 miles.
Is it worth renewing the oil pressure sensor or should I drop the sump and have a look at the oil pump and pipework ?
I'm tempted to think it's just an electrical fault but a low oil pressure light is a worry.
The steering warning light is also on, along with bulb fail and airbag.
So the dashboard is like a christmas tree.
But I still enjoy driving the 'powerful' little beast.
Any help greatly appreciated.
Regards,
Simon
simondenison is offline Reply With Quote Quote
Old 10-01-2016   #9
You need to get an oil pressure test done
The switch works on a present value removing the earth thus taking the light out
If the pressure drops below the preset value itll create an earth and put oil light back on
An oil pressure test will show if there is a low oil pressure fault
Has there been a recent sump replacement?
When was the oil filter last changed? A blocked filter may cause a low pressure fault
Ziggy
Meet Bumble-Bee
Old 21-09-2019   #10
Quote Originally Posted by Marc Lewis View Post
Hey whatever happened about your Mk2 Punto sporting? what was the cause of the problem / solution? I'm having similar issues with my Year 2000 MK2 sporting - I believe I have a crack at the top of my oil pickup tube
deeinlondon is offline Reply With Quote Quote
Old 21-09-2019   #11
I think I might have this same problem based on what I thought I could see with an inspection camera but I've searched online loads and can't even find a single mention of Cracked Oil Pickups in Fiats - nor any photos or video of a cracked fiat oil pickup - do you have more information on where you saw this?
(T) 110F Oil Pump options and low oil pressure woes marcus550 500 (Classic) 28 17-01-2017 21:02
(G) oil pressure warning light on, oil level full tjo Punto (Mk2/2b) 7 31-01-2012 14:48
(G) low oil pressure warning then engine control mangement light on ashj24uk Multipla 11 04-01-2010 10:52
(T) low oil pressure warning light Gaz Lear Stilo 2 15-09-2006 16:28
Oil pressure warning light at low revs oink FIAT Boo Archives 5 28-01-2005 16:19
