I have a few problems but i've not seen any threads with exact problems as my 1.2 8v 2004 punto.
Firstly I have thick black smoke coming out my exhaust constantly wether or not the engine or hot or cold and it's black staining the road when parked up and when moving or revving you can see lots of black smoke coming out and it stinks inside and outside of the car.
Secondly when reversing or setting off in 1st or 2nd gear i have horrendous loud rattling coming from underneath the car i'm assuming its a loose exhaust or something.
Thirdly i seem the have a loss in power but its not all the time it sometimes occurs when changing from 1st into 2nd gear and i lose alot of power and the revs drop right down as if i've accidently slipped it into 4th if that makes sense.
And the other power problem is when going up hills i know now its only a 1.2 engine but sometimes i have to drop into 2nd in some extreme cases just to get up a not so steep hill and its really embarrasing.
Finally on power when i'm on motorway or bypass accelerating to 60 or 70mph the revs jump up and down as if its gaining then losing then gaining power.
Oh and my mpg is really bad recently hitting 19mpg round town and 28mpg if im lucky on long journeys when it used to hit like between 40 to 45mpg on long journeys.
I'm on the verge of getting rid of it because its costing so much money.
It's 1.2 8v 2004 77k on clock
Just to help anyone heres whats been replaced so far.
- HeadGasket
- Radiator fan
- Battery
- Wiper motor
- Clutch
- Starter Motor
- Catalictic Convertor
- o2 sensor
- Air Filter/Oil filter
- Spark Plugs
- Handbrake Cables
SOMEBODY PLEASEEEE HELPPP
- HeadGasket
- Radiator fan
- Battery
- Wiper motor
- Clutch
- Starter Motor
- o2 sensor
- Spark Plugs
- Handbrake Cables
