there should be the "special tool" in the spare wheel compartment to undo the funny bolt things, and there should also be a screwdriver. (tip: with the screwdriver you can pull the handle off the metal bit and reverse it for flat/cross drivers...)
Fiat are sometimes really thoughtful...
It should tell you how to change a bulb in the owner manual
