Hi guys,
Today my 1.9JTD engine stopped when driving home ( with engine light and oil light on ) but started right away.
When arriving home i checked the error and it was P1320 - Cam/Crank synchronization.
I searched the forum and many described that replacing the RPM sensor fixed the problem. I also found the guide on how to replace it.
My question is the folowing:
The sensor connects into a conector clip which wire goes somewhere up.
Can someone let me know if there is another connector after the conector clip or if it goes straight to the ECU?
Regards
Rui
Regards
Rui
