Y Yaj New member Joined Apr 9, 2015 Messages 3 Points 1 Apr 9, 2015 #1 Mk2 diesel punto Does not want to start I know battery, heater plugs, crank shaft sensor, oil filter, air filter all ok checked pressre to the pump and injectors it's not the prime pump All help much appreciated
B bub2006 New member Joined Mar 26, 2015 Messages 35 Points 7 Apr 9, 2015 #2 does it just crank? If so does immobiliser light go out?
OP OP Y Yaj New member Joined Apr 9, 2015 Messages 3 Points 1 Apr 10, 2015 #3 It goes out when you crank her over
OP OP Y Yaj New member Joined Apr 9, 2015 Messages 3 Points 1 Apr 10, 2015 #4 Today tried mass airflow sensor Egr valve, fuses relays Discovered today it will start on easy start but the second you stop it dies
