I don't think my radiator fan is working when it's supposed too. Should it turn on when the temp gauge goes over halfway? or when the gauge enters the red section?
The fan doesn't seem to come on at all (I know its cold at the moment but yesterday I let the heat get up to about 3/4's before letting it cool down again to see if it would start the fan)
Now the fan works if its wired directly to the battery. I've had the relays off and properly tested with 12v bench supply and multimeter. They click when voltage applied, have internal resistance of 70 ohms. The maxifuse appears to be fine.
Finally I disconnected the coolant temp sensor with the engine running and rather than the fan kicking in straight away it took a few minutes. When it did start it would be going on for a few seconds and off randomly. I plugged the sensor back in (showing half way on temp gauge).
Is the ECU giving the wrong values to the relay?
