Well this is the issue, the clutch makes a horrible noise almost like grinding when it travels up and down. When you hold it down its silent and when fully up in gear its silent also but when you push it and make the pedal travel there is resistance and the grinding noise to mee it seems like its binding or the springs arnt working that great but this hasnt happened over night as the clutch pedal has went from perfect , then a slight squeek and now this horrible noise but the clutch its self works perfectly with no slipping or hesitation and engages perfectly in the middle!
