General Headlights on - ignition off !
Stevenage, UK
Quick question to anyone :
Do all Puntos have the ability to turn headlights on with the ignition off?
I switched my car off, took the key out and knocked the 'lights pod' on the steering column forward, the lights came on, shock-horror!! I thought the lights couldn't come on with the ignition off?
Just wondering....
yes on the mk2
The "follow me home lights"
Dont show on the dash board
But each high beam flash will give you a 30second healight and rear sidelight light
on the mk2b's it'll tell you how long you activated it for :)
i think the max is either 210seconds or 3mins cant remember
But its nice if you walk down a dark drive or just nipping to a cash machine which is dark, you dont have to leave lights on
Alot of cars have a basic follow me, my mums picasso will do it for 30seconds only tho
Ziggy
As Andy mentioned this sounds like the follow me home feature which few are aware of and even fewer use. With the key out if you pull or push the light stalk the lights will come on for a few minutes to let you drop the keys on the floor in the dark, find them and open your front door :)
its Pull
High beam flash
1 flash = 30seconds
push back locks hi-beams on, which iirc doesn nothing
Ziggy
yes on the mk2
Ziggy
thats in punto factory manual
