![]() | #1 |
![]() | power steering light...again my power steering light sometimes stays on after start-up, after speaking to the dealers, they reckon the cause is.....i have big feet ![]() ![]() it may be possible cause occasionally i feel my feet on the steering shaft, but think nothing of it my question is, is there any sensors on steering shaft or nearby? are they fobbing me off, to save themselves a job and me a trip up to see them it's under warranty and have something done to power steering light a few weeks after i got it, im hoping they would of sorted out the orginal problem with it and this is a different one cheers ![]()
__________________ Gaz FIAT No More |
![]() | #2 |
![]() | Re: power steering light...again There are sensors, but not on the shaft by your feet, they are all internal behind all the coulings - I believe the problem is that your dealer is a bit rubbish. If they carried out a 'Examiner' check there would be a fault stored - you would then start to make a diagnosis from there. Worse case you will need a new steering coloumn assembly - but there relatively easy to fit, plus its warranty so whats the problem with the dealer - contact Fiat customer care and tell them exactly what happened and that your "really concerned for your safety" ![]()
__________________ ![]() VW Golf GTi "power is nothing without control" |
![]() | #3 |
![]() | Re: power steering light...again thanks for the info ![]() this was a diagnosis over the phone lol the dealer is 45mins - 1hr away , so try not to go there if i can i hope my warranty is still intact, they not contacted me about my service which is over due ![]()
![]() | #4 |
![]() | Re: power steering light...again What size feet do you have Gaz?
__________________ Now drives: BMW 635d (wow!) Past: Renault Laguna Coupe GT 180. Laguna Initiale dci. 52 Megane 1.9dCi, Y-reg Fiat Brava JTD (Pale Blue) (2006), '51 Fiat Brava 80 SX (black) (2006), M-reg UNO (2003-2004) |
![]() | #5 |
![]() | Re: power steering light...again 12 , they not exceptionally big ![]()
![]() | #6 |
![]() | Re: power steering light...again Which was going to be my reply, I am sure FIat wouldn't have designed the car that way - unless Italians have small feet.
![]() | #7 |
![]() | Re: power steering light...again they just using a **** excuse, just wanted to check
![]() | #8 |
Posts: 83,532 Thanks: 1480 Trader Rating: 10 ![]() | Re: power steering light...again only one size smaller than mine an i have no light, are you not supposed to ring them when service is due?
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #9 |
![]() | Re: power steering light...again but you have no clutch, i seem to be catching steering shaft when i go for clutch pedal you most probably are suppose to phone but they usually send out a reminder ![]() ![]()
![]() | #10 |
Posts: 83,532 Thanks: 1480 Trader Rating: 10 ![]() | Re: power steering light...again ![]() you most probably are suppose to phone but they usually send out a reminder ![]() ![]()
![]() | #11 |
Posts: 1,723 Thanks: 104 Trader Rating: 0 ![]() | Re: power steering light...again Its not the dealers fault if you dont book your car in for service, if the warranty is invalidated then you lose out.
__________________ ![]() |
![]() | #12 |
Posts: 83,532 Thanks: 1480 Trader Rating: 10 ![]() | Re: power steering light...again you can re validate warentys ![]()
![]() | #13 |
Posts: 1,723 Thanks: 104 Trader Rating: 0 ![]() | Re: power steering light...again Costs £60 though, just because the srevice was late.
![]() | #14 |
Posts: 83,532 Thanks: 1480 Trader Rating: 10 ![]() | Re: power steering light...again be cheeper than a new steering coloumn assembly though wont it?
![]() | #15 |
![]() | Re: power steering light...again ![]() Its not the dealers fault if you dont book your car in for service, if the warranty is invalidated then you lose out. ![]()
![]() | saviogimmi | Punto (Mk2/2b) | 12 | 29-11-2010 21:23 |
![]() | Insane | Stilo | 1 | 21-03-2005 12:49 |
![]() | minislapper | Cinquecento / Seicento | 4 | 17-03-2005 14:15 |
![]() | bernieeccles | Cinquecento / Seicento | 10 | 20-12-2004 19:08 |
![]() | dawozere | Cinquecento / Seicento | 7 | 27-02-2004 16:30 |
