Jamesclegg1994
- Jan 7, 2015
- 24
- 4
Try holes in the exhaust mines was eating petrol with that plus my injectors were on the way out
Hi, I have joined the group because I have the same problem. It may well be the cold weather but the other thing to consider it could be the lambda or engine management temperature sensor. Anybody else had problems recently, my car is Mk2 1.2. I have no temp problems, it goes to half way and stays there but I have closed off half the rad with some cardboard to help warm up times.
SOLVED: Bad running and shaky engine
The problem was the spark plugs cables which was very bad inside and didnt plug well into the spark plugs, which caused the engine to jump and running bad and be shaky.
SOLVED: bad Consumption of fuel
After I changed the airfilter, spark plugs and spark plugs cables, all with brand new, the fuel gauge on the dashboard increased from 10.8 to 14.4 km/l. (In cold wheater)
NOT SOLVED:
The cars engine temperatur dosent stay on 90* degrees when I drive, and thats even if i drive in half hour long road. And its takes very long time before the temperatur arrow to rise up. I will provide images of how it looks like later.
Muddz;4015872 The cars engine temperatur dosent stay on 90* degrees when I drive said:This is typical of a thermostat that is sticking open. There is too much flow to the radiator which is overcooling the motor. The faster you drive the more cooling air you get. When you slow down in town the temperature rises a bit.
Brendan W;4015880]This is typical of a thermostat that is sticking open. There is too much flow to the radiator which is overcooling the motor. The faster you drive the more cooling air you get. When you slow down in town the temperature rises a bit.
How do i test if the thermostat is sticking open? Can i take it out and look at it?
The needle should be at the halfway mark +/- the width of the needle all the time after warm up which even in your ambients should take less than 8 km driving at approx 80 kph.
For normal driving use the only exception is when stopped in traffic the needle can creep up a little before the fan cuts in.
Here is how its look like when I'm driving. I took this pic right after i stopped at red trafic light
my temp gauge was exactly there with a bad thermostat
