Old 10-01-2015   #1
Ireland
Attaching handbrake cable
Hey folks...
Just had my Punto through the NCT (Ireland's MOT) and I have a few issues to sort out to get it to pass - most of which are very easily sorted.
One problem they pointed out was that the handbrake cable on the driver's side is hanging down just in front of the back tyre... when I checked it seems as though there's a bolt missing which would hold the clip on the cable itself to the underside of the car.
Would anyone happen to have a picture or diagram of how this should look, just so I know I'm doing it properly.
I'd imagine it's fairly straight forward, but just want to make sure it's done right!
Thanks.
AdamMaguire is offline Reply With Quote Quote
Old 10-01-2015   #2
flisko has donated!
Re: Attaching handbrake cable
just use zip tie
flisko is offline Reply With Quote Quote
Old 10-01-2015   #3
Ireland
Thanks - that's the plan, just want to make sure I'm fixing it correctly!
Old 10-01-2015   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
There should be a flexible bit of metal which holds it down
However they snap due to rot
As a result the cable hangs off
You can cable tie it on
Bond/glue some thin metal strip on but that could fall off too
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 11-01-2015   #5
atom0007 has donated!
I've found that cable ties can cut their way slowly through the cable sheath.
I put a bit of fibre reinforced tubing over it first, then cable tie. Works fine.
atom0007 is offline Reply With Quote Quote
Old 11-01-2015   #6
Quote Originally Posted by atom0007 View Post
red neck it - hose pipe
Ziggy
Likes atom0007 liked this post
Meet Bumble-Bee
(T) Handbrake cable.....I think thefrannyman Cinquecento / Seicento 12 21-06-2009 16:13
(T) handbrake cable pauljj40 Punto (Mk2/2b) 2 16-12-2007 16:08
(T) handbrake cable which one nogin Cinquecento / Seicento 3 18-11-2006 20:46
Handbrake cable??? gemmal Lets Talk FIAT 2 03-07-2006 16:36
handbrake cable Rizzini7 FIAT Boo Archives 0 03-04-2006 20:59
