Old 16-12-2014   #1
Unhappy MK2b won't start, won't turn over.
Attempted to start my punto earlier, got it started with a little acceleration for a few seconds before it stalled.
After this, any attempt to start it fails. Doesn't turn over, tries to for a split second before it all goes quiet.
When my ignition is turned, my lights work fine, so the battery isn't dead?
Jump start didn't change anything
Last driven 3 days ago.
Help! I don't mind if you're patronising, I'm ignorant towards cars :/
Creepy Nick is offline Reply With Quote Quote
Old 16-12-2014   #2
Student Mechanic
joncoxon has donated!
Re: MK2b won't start, won't turn over.
when the key's turned to position 2, can you hear the fuel pump prime, a slight hum from under the rear seat. My initial thought. does the starter motor still try to engage also?
joncoxon is offline Reply With Quote Quote
Old 16-12-2014   #3
Quote Originally Posted by joncoxon View Post
Yes it does prime, it 'tries' to start for about half a second or so, before slowing to a halt and silence.
Old 16-12-2014   #4
Trader Rating: 5
fingers99 has donated!
That's normal for the fuel pump.
First guess is that the battery is too flat to turn the engine over. The starter draw is vastly more than the lights. Recharge or jump leads.
Second is an earth fault. Try a single jumper lead from battery negative to a solid, metallic part of the engine or gearbox.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 16-12-2014   #5
Brendan W has donated!
Ireland
And check the security of the connections at the starter motor.
2001 1.2 8v
Brendan W is offline Reply With Quote Quote
Old 16-12-2014   #6
Quote Originally Posted by fingers99 View Post
Tried a jump start earlier, made no difference. still fails to even crank up, it does for a split second then slows to a stop
You mean a single jump lead from my negative terminal to a metal part of the engine?
Old 16-12-2014   #7
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Quote Originally Posted by Creepy Nick View Post
So we have a no start situation
Check
A the battery voltage is okay
B The battery terminals are clean and secure
The negative jump lead on engine mount and then to the battery negative is a good way when the engine turns over poorly due to a poorly earth
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 17-12-2014   #8
Quote Originally Posted by Ziggy122 View Post
Check
Ziggy
Negative to ground didn't do anything either. I'll upload a video to show you what its doing.
Old 17-12-2014   #9
Negative to ground didn't do anything either. I'll upload a video to show you what its doing. https://www.youtube.com/watch?v=OgjZgqxLFjc
Have you tried leaving the battery on charge for a few hours and try starting it then. Maybe something wasn't right when you tried jump starting it
oXRUSSXo is offline Reply With Quote Quote
Old 17-12-2014   #10
Or have you tried rocking it to see if its stuck in gear. Try with the simple solutions first
Old 17-12-2014   #11
The starter is engaging but no engine turning over (solenoid on starter working)
Id be checking thr engine can turn over by hand
Either the battery is flat as a pancake ir id suspect the starter has died
Meet Bumble-Bee
Old 17-12-2014   #12
If you stick the battery on charge overnight you will rule out the flat battery which is possible with this freezing weather if your battery was low anyway.
Then I would start looking at the starter motor
Old 17-12-2014   #13
flisko has donated!
you can also probably rule out alternator as when my alternator brushes were gone there was just a click when i turned key
flisko is offline Reply With Quote Quote
Old 17-12-2014   #14
Trader Rating: 5
Quote Originally Posted by flisko View Post
But that's just the battery having gone flat as a result of the alternator failure.
I suspect deceased battery -- lots of places will test fer nowt.
M12 fund 20
Old 17-12-2014   #15
I'll check the battery voltages tomorrow
Likes oXRUSSXo liked this post
(T) Engine won't turn over HanFob93 Punto (Mk1) 2 08-05-2014 09:59
(T) engine won't start won't bump start engine seized ? seanhyde Cinquecento / Seicento 43 23-01-2012 14:33
new mamber help engine won't turn overor bump start seanhyde Newbie Central 2 13-12-2011 16:16
(T) Engine won't turn over/start Kalby Punto (Mk2/2b) 4 25-05-2011 12:48
(T) Car won't turn over BrumBrum Punto (Mk2/2b) 19 05-11-2009 09:52
