![]() | #1 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Starting Issue Hi all I have just bought a 52 plate Punto so my wife had a reliable car following our Landrover Discovery breakdown issues. Well 2 days in and the Punto is disgracing itself. Car opens on the button, put key in and all the lights come on. Turn the key and nothing...... It is intermittent, it may start and get you from A to B then decide not to start again as you attempts to get from B to wherever...... It is now abandoned in ALDI car park and I am likely to get a severe kicking for buying another pile of crap when I get home. I am inclined to think it is an earthing issue but anm open to suggestions from those more experienced in Punto ownership. Jon
![]() | #2 |
Posts: 16,588 Thanks: 912 Trader Rating: 0 ![]() | Re: Starting Issue So you turn the key - you get a click and thats it? To me that sounds like the main gearbox earth to body to battery negative failure Usually a corroded terminal or wiring Ensure the battery is fully charged Stick a negative jump lead on the engines side of the engine mount - and then clip the other side onto the negative terminal of the battery Then turn it over - does it start 10x better then before? Yes - see the above No? - Report back Take it no warning lights on dash - no error codes? - Anything recently been done it? Dont lash out on the first instance of a breakdown, its only a breakdown, not WW3 or end of the world as we know Ziggy
__________________ |
![]() | #3 | ||
Posts: 55 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue Immobiliser fault? Do you get the Key/Immobiliser Warning light?
![]() | #4 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue What am I looking for with the immobiliser please?
![]() | #5 |
Posts: 3,025 Thanks: 217 Trader Rating: 0 ![]() | Re: Starting Issue Light on the dash that won't go out - key code warning. Can't for the life of me remember what it's like but it should be obvious ![]()
__________________ 2001 1.2 8v |
![]() | #6 | ||
Posts: 101 Thanks: 3 Trader Rating: 0 ![]() | Re: Starting Issue go back to basics * how many keys do you have - if you have 2 try the 'spare' * when the car won't start is there a click from the starter? YES = check earth lead on battery plus the engine to chassis earth + rock the car ignition OFF but in 2nd gear to see if the starter has jammed -- doubtful by the intermittent issue * NO = could be starter motor - less than £100 exchange at local factors but first look on the dashboard look for a yellow car symbol with a padlock around it - means the immobiliser is locked - that could be 'coil' around the barrel of the ignition lock but again intermittent suggests a wiring fault and a need to check continuity of every single wire of both ECU connectors - as that's a dealer cost of circa £200 to locate and fix you may wish to spend a day with a multimeter yourself * have you got Multiscan - if it will connect it's not likely the immobiliser *
![]() | #7 | ||
Posts: 55 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue The light on my dash shows a picture of the front end of a car with a padlock! Other models show pictures of a key (IN ORANGE OR RED) If it's immobiliser related, the car will turn over like it's trying to start, but wont... If you get nothing when you turn the key it's likely to be starter motor, or earth fault, or alternator as other have mentioned! Al
![]() | #8 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue Thanks for all the help guys. The prize in this case goes to Ziggy122 as it was indeed the earth lead. Looks like a new one for fitting at the weekend. All in seems not a bad wee car. Look out for my next post. Why is the heater so flipping poor. Jon
![]() | #9 |
Posts: 3,025 Thanks: 217 Trader Rating: 0 ![]() | Re: Starting Issue Airlock possibly. Is there a gurgling noise from the heater on startup? Sticky thermostat is another possibility. Do you have a temp gauge and is it sitting in the middle all the time after warmup?
__________________ 2001 1.2 8v Last edited by Brendan W; 03-12-2014 at 19:08. |
![]() | #10 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue Brendan W I have noticed a slight moaning noise from under the bonnet and it sounds similar to an airlock in my old Landrover so will bleed the system first.
![]() | #11 |
Posts: 3,025 Thanks: 217 Trader Rating: 0 ![]() | Re: Starting Issue These cars are a bit tricky to bleed as they don't have a header tank as such. Filling the rad to the top of the filler neck helps. There is lots of advice and help on here. Persistance pays. Moaning is unlikely to be airlock related. Alternator belt or bearings would be a good starting point.
__________________ 2001 1.2 8v Last edited by Brendan W; 03-12-2014 at 19:56. |
![]() | #12 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 ![]() | Re: Starting Issue Thanks Brendan W, I'ii check those out. Regarding the heating, the needle sits bang on in the middle once warmed up so I am relatively happy with the the thermostat. The heater works reasonably on full when teh car is driving (though not as hot as I would expect). Once you stand still it hten cools rapidly until its just cool air coming out. I will look on how to bleed the system and hopefully it will resolve the issue. Jon
![]() | #13 | ||
Posts: 2,377 Thanks: 105 Trader Rating: 0 ![]() | Re: Starting Issue Check tightness of battery clamp connectors and cleanliness of terminals/clamps Check condition of earths, lots of threads on that here
![]() | #14 |
Posts: 3,025 Thanks: 217 Trader Rating: 0 ![]() | Re: Starting Issue In particular, when you get a moment remove the back light clusters and have a look at the black earth wire and pins at the plugs. They have a tendancy to corrode and cause all sorts of funny electrical issues. A good blast of contact cleaner will head them off.
![]() | drof | Grande Punto | 4 | 15-10-2014 10:20 |
![]() | duckdriver | Ducato | 11 | 01-04-2013 14:08 |
![]() | fiat newbe | Grande Punto | 8 | 25-02-2013 22:04 |
![]() | paul6693 | Punto (Mk2/2b) | 1 | 21-06-2009 17:30 |
![]() | marino | Cinquecento / Seicento | 9 | 12-06-2009 23:11 |
