Styling Black Angel Eyes fitted at last
Nice work, makes the whole front end alot meaner
(y) :slayer: :worship:
did they have to be hard-wired or do they plug straight in? just want to know cause im expecting mine on wednesday! i think they should look good cause i have the rear clusters smoked out so the car will be like a shadow! or a batmobile. (maybe not)
like the badboy bonnet aswell.
Thanks for the comments. They are v.easy to fit, with mine there were two connectors which plug straight into the main and full beam lights, and apair of wires for the angeleye light, small LED lights and the inner light which can also be used as a indicator. i didn't cut any wires to fit mine i just used block connectors, so i'll be able to change back to the standard light units if needed.
is there anywhere you can buy the black angel eyes apart from ebay?
and how are the angel eye rings wired in? an idiots guide would be good (or a sticky with pics if anyone wants to do one :p lol)
charlie
The angeleye lights are wired to the sidelights, i can pm you a pick later in the wk if needed. I got mine from Bodystylist from the puntosports forum.
yeh an idiots guide would be great,just in case there was any idiots wonderin how you do it. er....on a different subject where did you get the block connectors?could you justuse a soldering iron? im nifty with one of those. im thinkin that if theres an agel eye and an led that youl have to make a double connection to the existing sidelight wire. is that dangerous? wouldnt like to be startin a fire or nout!:slayer:
Will try and take some pics on Thusday, and yes you can use a soldering iron if you want. You can get block connectors from any electrical store or even B&Q. Also yes i have a double connection as you call it, the LED light and the Angeleye ring are both connected to the same sidelight wire. I doubt if it'll cause any fires mate.
