im Axle Specialists
Old 09-09-2005   #1
Question How is the radiator fan controlled?
On a 2000 (MK2) 1.2 ELX how is the radiator fan controlled? What makes it kick in? I see there is a resistor on the fan itself. What is this for? Is that just for the temperature gauge inside the car? What makes the relay trip when the temperature gets too high (and what temperature does the fan normally kick in on everyone elses car? 3/4?)
Thanks,
Neil
NeilB is offline Reply With Quote Quote
Old 09-09-2005   #2
Malta
Re: How is the radiator fan controlled?
IIRC there is a temp sensor on the block, that sends the voltage signal to the ecu, the ecu trips a relay (found in the fuse box in the engine bay) which in turn switches on the fan.
--- Punto mk2 8v---
*Int & Ext neons**Tinting**Int Alum trim**Momo gear set**Momo pedal set*
*Body graphics**Custom Ice install**Custom A'Pex Integration CAI**Sports exhaust**Racing Seat Belts**Removed seats**Lexan Windows**Weight reduction*
Neo-The Matrix is offline Reply With Quote Quote
Old 09-09-2005   #3
If I want to bypass this sensor to just make the fan kick in, how do I do this?
The resistor contacts are all green and corroded (like when a battery leaks). One end of the resistor has come unsoldered but is still touching where its meant to but its covered in this green stuff.
As you can tell, I'm not a mechanic
Old 09-09-2005   #4
Here are some pictures of under the bonnet
This is the radiator resistor which fell apart in my hands (see pic 2)
See how its all corroded? Is there a way I can short this out to test the fan?
This is how my water filler looks, the white on it, does that look as if its been overheating?
Is this fluid from my air con? Or heater matrix??
Thanks,
Neil
Old 09-09-2005   #5
Aircon
"Every day, in every way, I get better and better"
NumanR is offline Reply With Quote Quote
Old 09-09-2005   #6
Forum Moderator
T14086's Avatar
T14086 has donated!
You can bridge out the relay but if your not comfortable with this then dont try it,you can blow the ecu! Buy a new resistor,fan cuts in about halfway on temp gauge.
Old 10-09-2005   #7
Malta
Temp should be half way for fan to kick in.
I think you did have a minor overheat there.
The way I test the fan is to go at the fan motor itself, there should be 2 wires on the motor, disconnect them. Then wire the +ve side of the motor to battery + and the -ve side of the motor to battery -.
If you do not know what you are doing do not continue cause I do not want to be responsable for loss of limbs, bad ecus, messed up fan motors etc...
--- Punto mk2 8v---
Old 12-09-2005   #8
Burninator of threads!
faster4_tec's Avatar
faster4_tec has donated!
Mongolia
Has your car been in the sea or something, as it is seriously corroded under there!!
Volvo for Life
faster4_tec is offline Reply With Quote Quote
Old 12-09-2005   #9
Forum Moderator
T14086's Avatar
T14086 has donated!
LOL,poor guy wont sleep tonight now!
Old 12-09-2005   #10
Right we're making progress. Proven today it's the radiator fan thats broken. Bypassed the relay and supplied 12v direct to the fan and it's dead.
(T) Electro-magnetic Locks (remote controlled lock system) Tempra1.6 Tempra 2 20-09-2004 12:01
