Is there any way I can change the style of the lift up reverse thing on the gear stick? When change the gear knob i cut the old one off an took a couple of chunks out of the lift up reverse bit + I dislike the look of it + it doesn't fit well with the gear knob, ie. you can see the spring(even though of the packet of the knob, it said it was ok for lift up reverse).Thanks, Pandamonk
