I have a punto 55sx with factory fitted sunroof, when it rains water dripps out of the interior light, I can't see where its comming from, any ideas???
Common problem, its coming through the roof ariel. Remove the lamp housing and you can see the ariel lead and the base of the mast. Remove with a 10mm socket and clean up the joint and reseal with silicone sealant. Rebuild and tighten in position. NO LEAK.
