Rear springs pop out rather easily once the car is supported on axle stands on the sills (bad i know but its only way to securly hold it)
Removing the top gas strut bolts - as the bottoms often seize in, and the rear springs will pretty much then just fall out
my bump stops are playing pin ball inside my rear springs, you can try bonding them back down, but it wont last i suspect
Ziggy
