stevielloyd1985
- Nov 22, 2014
- 4
- 1
Car upon start up Judders really badly and that is how it stays, when I try and pull away it stalls!
Back in August, I replaced the head gasket, thermostat, water pump and timed it all up nicely. It was running like a dream up until last week, when it just felt like it wanted to give up all of a sudden. I am going to do a compression test when I can manage to get one tomorrow to see if there is anything a miss there, but I really cant see it being that.
I replaced the plugs, leads, coils and dropped a new virginised ECU in, incase of the old 2 cylinder misfire problem....... No joy!
The resistance on the injectors are even, and they were cleaned not too long ago, so Iv'e ruled them out! The voltage from the fuel pump loom however, fluctuates and does not give a constant reading! I have checked all fuses and they are all in order.
The problem started after I had to drive along a windy bumpy road last week! Possible that the timing may have slipped even though it was changed in late August? I'm at a loss and any opinions would be great.
