darashen
Hi everyone, just wanted to sound this out with people.
My 2003 1.2 8v with 48k miles normally runs perfectly. I have recently had two instances of it failing to start. Both times it happened in the same underground car park a month apart. The car had been driven 5 miles, parked for 45 minutes and then would not start. Cranking the engine and pumping the accelerator pedal eventually got it started again.
When turning the engine over on both occasions it sounded like no fuel was being injected.
My heat shield went missing a few months ago whilst some engine work was being done. My theory is that the lack of heat shield and the lack of airflow in the carpark is causing heat to remain in the engine bay and causing the fuel in the fuel rail to vapor lock. Cranking the engine forces fresh fuel into the rail eventually displacing the air lock.
No engine light and no fault codes. What does everyone think, is my theory likely or could it be some other fault.
Anyones input appreciated and sorry for the long rambling post.
