Hi all,
I've seen a couple of threads asking similar questions lately, so apologies if I seem to be overlapping with those.
I'm having a bit of trouble with my '00 Mk.2 Punto.
A couple of months ago, it started running rough, misfiring and losing power (not cutting out though). Took it to my mechanic who replaced the plugs and leads, which needed doing anyway. It didn't solve the problem, so I took it back to him and we discovered mayo in the radiator- the head gasket was gone. He replaced that, which, again, needed doing. That didn't solve the problem either and, after a chat with a main dealer mechanic, neither did replacing the coil with a secondhand one.
I think I can rule it out as being a sparking issue, which leads me to think it must be a fuel problem. The mechanic seems to think that given my tendency to let the tank run to near empty, I might have damaged or clogged the injectors in some way. I was wondering if he was on the right track with this idea?
From some of the other threads I've read, it sounds plausible, even if it's a rare enough problem. I haven't hooked the car up to a diagnostic as the mechanic doesn't have access to one. Could it be many other things, or would I be right in going ahead replacing the injector rail with a secondhand one? Would anyone know how likely that would be to solve the issue?
Thanks,
Dave.
Thanks,
Dave.
