Yes, this is yet another Punto jerking thread.
The Car
Has anyone who has experienced these symptoms positively narrowed it down? I was thinking cleaning the throttle body (as per the guide here) or replacing it.
The Car
- Year 2000
- Mk2 (not 2b)
- 1.2 8v Petrol
- ~40, 000 miles (known to be genuine)
- Regularly serviced at an authorised garage
- Jerks/kangaroos when accelerating/decelerating in the rev range of 1000 rpm (1k) to 1500 rpm (1.5k). Smoother above and below(!) this range.
- Naturally difficult/annoying to drive in slow traffic with this
- Full throttle acceleration does not exhibit the problem - slow controlled acceleration in the affected rev range, does.
- No clutch use is occurring whilst this going on (actually need to depress the clutch pedal to avoid it).
- Particularly noticeable in 1st and 2nd gear
- Exists in a warm engine or cold
- Visibly unsteady idle needle
- Irregular idle "pulse" / "cough" every few seconds (irregular timing) can be felt in the seats/steering wheel also
- Clutch. Recently replaced, no difference. I've experienced slipping clutches before. There's the fact that it's bad when decelerating (i.e. when I would imagine the clutch is under less load).
- Timing belt. Also recently replaced.
- Rear (dog bone) engine mount. Recently replaced.
