If youve got a few spare hours on ya hands have a go at sticking some Golf wipers on ya car! It aint a piece of pi** but looks good and works better, heres how I did it:
First I got a set of wipers from a car in a scrap yard (also got a spare set for my punto whilst I was there)
The VW wipers are put together quite well, you need to take the ends off only, I got a screwdriver and hammered my way down the join on the underside of the VW wipers. They should then slide out, they are not welded.
Then after placing the VW wipers on the screen is the desired position I marked off on my spare set of Punto wipers where they come up to. I cut the end bits of the Punto wipers off (leaving an inch or 2 for the VW end to grip on).
I then flattened the end of the VW ends so they would grip the punto arms which I forced in (I also did a spot of welding on the back to make sure it was solid). Then prepped and sprayed the whole lot in matt black.
Sorted.
Sorted.
