Hi mate,
The alfa one is similar but not the same.
Pin 1 - White and green
Pin 2 - Light blue and Brown
Pin 3 - Light blue and White
Pin 5 - White and Black
Pin 6 - Black and Pink
There should be continuity between pins 2 and 5. these 2 pins deal with over and under pressure. If the pressure is either over 28 bar or under 2.45bar it will break continuity between the two pins and cut the compressor.
1 and 6 will have continuity when the pressure rises above 15bar and this will turn on the first speed of the cooling fan.
3 and 6 will have continuity when the pressure is above 20 bar and will turn on the second speed cooling fan.
The frost stat that is located on the evaporator comes before the 4 stage pressure switch.
When the AC is switched on, the signal goes to the thermostat, then if the thermostat wants the compressor to engage, the signal goes direct the pin 2 on the pressure switch.
Hope that makes sense.
Alan
