P1nkPr1ncess
- Jun 15, 2012
- 11
- 3
Hi all,
Hoping someone on here can answer my question because the main Fiat dealer couldn't and I can't find the answer on Google!
I need to replace the body control module (BCM) on my automatic Fiat Punto. I have found a set (BCM, fuse box, ECU and key set) on Ebay with matching part numbers, it is also from a 1.2 16v car (perfect right?!) the problem is that it has come from a manual car and I have a sneaking suspicion that this isn't going to be compatible with my automatic?
Does anyone know?
I have the option to buy, try it and return if not but I would still be forking out the labour costs of the auto electrician and I don't know if it's worth it?
Can anyone help please?
-x-x-
Does anyone know?
-x-x-
