Got the rear badge in the post today.. How did you snap the two prongs off? I don't want to damage the badge...
Rhys
Rhys
Rhys
When you took off you original badge, was it just stuck on? I can't get mine off at all with hair dryer and fishing wire...
Rhys
I looked under the bootlid trim and there was no place for me to be able to undo a bolt. Also, I have read before that the badge is just glued on.Iirc theres a single bolt in the middle of the badge
On the new badge that I brought, it had two lugs.. I cut them off.. was this a bad idea?no bolt
they are located into 2 grommets to line it up and some sticky to hold it
you just need to eat more spinach and try again
Also, do I just need to heat up the area and then pull it off? Any tips on how to do this?
Rhys
