After having my clutch replaced a couple of weeks ago, its making a noise. Im not sure how long for as i only noticed today pulling down a narrow driveway.
Basically theres no noise when you press the pedal down, and no noise when you lift the pedal (in neutral)
When its in gear, pressing the clutch down is silent but as you start to lift the clutch and accelerate it makes a hissing noise, and stops when the clutch is fully lifted. Sounds a bit like rushing air (theres no noise when accelerating in neutral)
Also a few times I've noticed when reversing, as you lift the clutch and put revs on theres a humming noise, doesn't do it all the time, only every now and then.
Just wondering if its worth taking back to the garage to get it looked at or if its nothing to worry about?
Probably worth noting the clutch feels fine, no slipping, the biting point feels fine, very light, smooth, its not slipping or juddering and no ticking/knocking noises from it.
