Yes you can upgrade the clocks to a higher spec version, but there are a couple of caveats...
- You need to make sure they are from the same type of punto. Ie you cant fit Mk2b clocks in a Mk2 punto (without extensive modification anyway)
- The mileage on the new clocks should be LOWER than the actually mileage on your car to make matching the mileage easier.
- The new clocks
MAY require "proxy alignment" which will enable them to talk to the car correctly and set your correct millage from the BCU. I believe this can be done with Multi ECU Scan.
- Try and avoid clocks out of HGT or diesel models that have extra warning lights.
In your OP you mention fitting clocks from an "active sport" this would be a mk2b and would not fit your mk2.
The link you provide show clocks from a mk2
As said though, provided you meet all of the above caveats, it's a straight forward job.
Alan
