Hi All,
First of all, thanks for all the great advice on these forums. Using guides on here I've purchased a set of diag leads, downloaded multiecuscan and have had good fun working on my Son's Punto.
We've cleared a few problems of late (Power steering - new steering column and passenger airbag switch - switch cleaner!) but still have one issue remaining I could do with some advice on.
The drivers airbag light is on and multiecuscan shows:
08 - Driver squib circuit - Open Circuit - Intermittent/Present 123
I have cleaned connections at the airbag ecu, the passenger airbag switch (solved previous problem) and where the airbag loom connects the the steering column - I assume this is the squib? Error still exists.
Any advice on any areas I have missed (Passenger airbag connection?) or on what parts I should look at replacing first please?
Thanks in advance
Jamie
Thanks in advance
Jamie
