Thread Tools
Old 20-06-2014   #1
Question Camshaft position sensor error P0340 + melted airbox!
Hi Everyone,
So here's a long story short. I have a mk2 Punto 1.2 16v sporting.
The exhaust looks like it is causing the airbox to melt. I changed the bottom half of the airbox that contains the filter thinking it was caused by a recent overheating issue I had but its now melting the new airbox.
Connected to the ECU and it reads P0340 camshaft position sensor error code, cleared it but it comes back when the engine is started. I changed the camshaft sensor for a new one and still has the fault. There doesn't seem to be faulty wiring with that sensor.
Also has a P1135 pre cat sensor error.
Does anyone know what is causing the airbox to melt and how to rectify the camshaft position sensor error?
Much appreciated!
Bumblebee1 is offline Reply With Quote Quote
Old 20-06-2014   #2
Burkina Faso (Upper Volta)
Re: Camshaft position sensor error P0340 + melted airbox!
codes are a guide not the law
although you give some information you dont give all so im going to go for blocked cat causing excessive underbonnet temperature and error codes
oh and welcome
Thanks Bumblebee1 thanked for this post
s and b is offline Reply With Quote Quote
Old 20-06-2014   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Has it recently had a timing belt done? OR work related to timing, such as water pump or a tensioner?
As there tend to be 1 of 3 things i've seen beent he cause
1 - the timing is out, and the car is telling you that
2 - the Wiring is damaged, since you've overheated, could be the wiring has too!
3 - the sensor at fault
since you've done 3 already, i'd be inclined to just check the wiring from sensor to ecu
Unless you've had timing work done, then that needs checking first with the proper tools! No tipex here im affraid
P1135 = "Oxygen sensor heater resistance Bank 1 (Pre-cat)".
2 tests i'd be doing
Pin 3 and 4 - Autodata states resistance between 4 and 11 Ohms - sensors disconnected - this will tell you if the heater coil is going over resistive, or open circuit
Pin 4 and Earth - Check at Car wiring loom to the sensor (NOT THE SENSORS WIRING) - Disconnected - Should see 11v - 14v With ignition on, however i'd wanna see battery voltage or very near battery voltage
Ziggy
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 21-06-2014   #4
Busy rebuilding pand'a
oldhammer's Avatar
oldhammer has donated!
I had a melted air box on mine.
Its easy to fix.
Just find a exhaust heat shield to cut up or use a oven roasting tray..
Cut a square off it ..shape it to cover the lower part of the air box and fasten it on with some
10mm nuts and bolts..
Mines been fine since.. saves buying another air box that I'd guess would just melt again anyhow.
if some one has helped you here click the thanks button it costs nothing,
oldhammer is offline Reply With Quote Quote
Old 21-06-2014   #5
oldhammer's Avatar
Re the timing issue'
The phase sensor. Sees tdc on initial start up..so if timing is out
It will keep doing it.
Timing on these can be out 3 ways.. it couid be out on the inlet cam.
Get hold of a set of timing tools and see if both camshafts will lock off..
Do you understand what I mean..
If not just give us a shout and I will explain further..
Old 21-06-2014   #6
Quote Originally Posted by Ziggy122 View Post
Ziggy
Ziggy
Thanks Ziggy. I've checked the Lambda sensor and wiring.
Pins 3 and 4 = 10.5Ohms
Sensor disconnected then probed Pin 4 to Earth on ECU wiring side with ignition on = 13V which was pretty much battery voltage.
The timing belt looks pretty tight so I don't think it's slipping but I could be wrong. I'm stumped. I've called a local garage and booked it in for Monday.
Old 21-06-2014   #7
I will take the CAT of tomorrow and have a look. Is it easy to tell if it is blocked?
Old 21-06-2014   #8
Just becUse the belt is still tensioned doesnt mean the timing is out if any work on it was done which u havent answered
Ziggy
Meet Bumble-Bee
Old 21-06-2014   #9
oldhammer's Avatar
No body listens on here Ziggy..
Old 22-06-2014   #10
Ziggy
No work was done on the timing recently. I've had the car for about 6 months or so.
Oh and Oldhammer, people don't listen.
Old 22-06-2014   #11
oldhammer's Avatar
Did the car come with Engine management light on when you first bought it.
Old 22-06-2014   #12
Quote Originally Posted by oldhammer View Post
No it didn't.
These faults should have triggered the light.
Sooo using the FiatECUscan I did an instrument panel test and the engine management light did not come on.
Seems a bit suspicious. Do these fail? Can the lights be "turned off" by someone trying to hide the fault?
I'm going to take the panel off and have a look.
Old 22-06-2014   #13
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
The lights on the dash are actually SMD (led) and cannot easily be removed, and I've never personally known one "go" of its own accord. A common trick though is to put some black tape over the SMD on the board.
The dash does a self test on startup, and if a SMD was faulty, it would say "LED fail" in the display where your mileage is.
To me, it says that whoever sold you this car couldn't solve the problem your having and simply taped over the SMD for the EML. Tut tut.
Alan
Likes homeward, oldhammer liked this post
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 22-06-2014   #14
oldhammer's Avatar
Quote Originally Posted by Bumblebee1 View Post
No it didn't.
Right OK..
What you need to do is ..check the timing..
My guess is its out..
You can use ..small socket extension bars to use as locking tools
One wouid have to be cut down tho to be able to lock off the inlet cam.
If your in Manchester I've got a set of locking tool's.
Old 24-06-2014   #15
Right OK..
Thanks. I used to live in Manchester but that doesn't help!
I don't have the time yet check the timing as I am away for a few days.
Thread Tools
(T) Camshaft position sensor, MAF & Engine speed sensor Cathalo Doblo 2 15-06-2012 20:45
(T) No signal from Camshaft Sensor P0340 Fault Code MaverickJ Ulysse 2 31-01-2012 01:04
(T) Camshaft Position sensor Lovatt Punto (Mk2/2b) 8 11-03-2011 17:27
(T) camshaft position sensor sporting_adz Punto (Mk2/2b) 13 10-11-2009 22:57
(T) Camshaft Position Sensor ? SwissTony Stilo 13 07-07-2007 22:26
